IS350g
Nov 25, 2019Aspirant
Netgear Orbi RBR20 hardwire speed issues
I recently upgraded my internet setrvice to 750/750. I plugged my laptop into my ISP modem and can always get 750/750 or higher. When I plug the same cable into my Orbi router, the max download speed...
Nov 25, 2019Guru - Experienced User
Are you speed testing with a PC and Ooklas speed test app installed on the PC?
Have you enabled the speedtest app on the RBR, Traffic Meter or Access Controls on the RBR?
- IS350gNov 25, 2019Aspirant
The current firmware is 2.3.5.26
When I plug my laptop directly into the modem I use Ookla speed test and everything is 750+/750+
Next I plug the same ethernet cable into the Orbi and run the orbi speed test and I get 520down/768up
I run the speed test on my laptop coming out of the Orbi and it does about 450-500 up/700 down
I haven't messed around with any of the traffic meter settings but I would assume the hardwired router should be perfect with up and down speeds of 750/750 if the modem is passing the speeds.
