IS350g
Nov 25, 2019Aspirant
Netgear Orbi RBR20 hardwire speed issues
I recently upgraded my internet setrvice to 750/750. I plugged my laptop into my ISP modem and can always get 750/750 or higher. When I plug the same cable into my Orbi router, the max download speed...
Nov 25, 2019Guru - Experienced User
Are you speed testing with a PC and Ooklas speed test app installed on the PC?
Have you enabled the speedtest app on the RBR, Traffic Meter or Access Controls on the RBR?
IS350g
The current firmware is 2.3.5.26
When I plug my laptop directly into the modem I use Ookla speed test and everything is 750+/750+
Next I plug the same ethernet cable into the Orbi and run the orbi speed test and I get 520down/768up
I run the speed test on my laptop coming out of the Orbi and it does about 450-500 up/700 down
I haven't messed around with any of the traffic meter settings but I would assume the hardwired router should be perfect with up and down speeds of 750/750 if the modem is passing the speeds.
- FURRYe38Nov 25, 2019Guru - Experienced User
Please review:
- IS350gNov 25, 2019Aspirant
My ISP is Telus and the model is a T3200M
Is this your modem?
https://www.actiontec.com/products/wifi-routers-gateways/vdsl/t3200m/
This already had a built in router which may cause some problems.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopLet us know what mode the modem is working in...
