IS350g
Nov 25, 2019Aspirant
Netgear Orbi RBR20 hardwire speed issues
I recently upgraded my internet setrvice to 750/750. I plugged my laptop into my ISP modem and can always get 750/750 or higher. When I plug the same cable into my Orbi router, the max download speed...
IS350g
The current firmware is 2.3.5.26
When I plug my laptop directly into the modem I use Ookla speed test and everything is 750+/750+
Next I plug the same ethernet cable into the Orbi and run the orbi speed test and I get 520down/768up
I run the speed test on my laptop coming out of the Orbi and it does about 450-500 up/700 down
I haven't messed around with any of the traffic meter settings but I would assume the hardwired router should be perfect with up and down speeds of 750/750 if the modem is passing the speeds.
Nov 25, 2019Guru - Experienced User
Please review:
- IS350gNov 25, 2019Aspirant
My ISP is Telus and the model is a T3200M
- FURRYe38Nov 25, 2019Guru - Experienced User
Is this your modem?
https://www.actiontec.com/products/wifi-routers-gateways/vdsl/t3200m/
This already had a built in router which may cause some problems.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopLet us know what mode the modem is working in...
Hi,
Yes that is the exact modem. When the installer came to set it up months ago, I asked him to put in in bridge mode so nothing is active as far as wifi from the router. It is just passing the signal to the orbi. As i mentioned, when i plug my laptop directly to the T3200M, I get the full speeds of 750/750 so I know it is sending the signal.
The issue is when I connect the T3200M to the Orbi, and then test the laptop again from the orbi output, the signal download drops to 450-500MBPS, while the upload remainds the same at 750+
