Mullet_Man
Jan 10, 2022Follower
Netgear Orbi RBR40 Replacements
I need to replace my Orbi RBR40 Router. I have 2 RBS20 Satellite units and an RBW30 Satellite. The replacemet router needs to be compatible with these satellites. Is there somewhere on Netgear's website where I can find a comaptibility matrix or can someone suggest replacement routers that will work with these satellites since the RBR40 cannot be purchased anymore?
1 Reply
Compatible:
RBR50
RBR40
RBR20
What you might look at is they still sell the RBK40, RBK43 kit on amazon renewed. You could buy the kit and sell the satellites (or use them) for fairly cheap. I also see the RBR50 go on sale renewed a lot. Fairly easy to find on ebay as well as people buy the kits for the satellites because its sometimes cheaper to buy the whole kit versus just the router and then sell the routers
