TheGuy18
May 12, 2020Guide
Netgear Orbi RBR40 router and satellites low speeds and drop connection
For the last few weeks internet has been dropping off, and is slower than normal. Normal download speeds are around 150Mb/s but most recently I am getting around 20Mb/s. The connection has also fully...
May 14, 2020Guru - Experienced User
Can you directly connect your wired PC to the CM modem and test speeds and some sites here?
Possible the RBR is faulty and needs to be replaced...
TheGuy18
May 14, 2020Guide
Unfortunately when directly connected to the RBR the speeds still dip to as low as 1/8 the normal speed. Luckily I believe it is still under warrenty so I will try to get it returned. Thank you very much for the help!
