LloydG
Dec 22, 2021Aspirant
Netgear Orbi RBR50 / Open reach modem UK
Good morning. Can anyone assist. I'm currently using a BT Smart Hub 2 but it doesn't have modem mode. So I've purchased an openreach modem model ( B-Focus V-2fub/r Rev.B). I've connected it to ...
Dec 22, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- LloydGDec 22, 2021AspirantMany thanks.
I've gone for AP mode.
Unfortunately my BT smart Hub 2 doesn't have modem or bridge mode functionality so I've disabled WiFi.
I'm not a power user so strictly speaking don't need router mode. However is router mode quicker than AP?- FURRYe38Dec 22, 2021Guru - Experienced User
AP mode would have better performanced that router mode since the RBR doesn't have to process many features while in router mode.
