LloydG
Dec 22, 2021Aspirant
Netgear Orbi RBR50 / Open reach modem UK
Good morning. Can anyone assist. I'm currently using a BT Smart Hub 2 but it doesn't have modem mode. So I've purchased an openreach modem model ( B-Focus V-2fub/r Rev.B). I've connected it to ...
Dec 22, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
LloydG
Many thanks.
I've gone for AP mode.
Unfortunately my BT smart Hub 2 doesn't have modem or bridge mode functionality so I've disabled WiFi.
I'm not a power user so strictly speaking don't need router mode. However is router mode quicker than AP?
- FURRYe38Dec 22, 2021Guru - Experienced User
AP mode would have better performanced that router mode since the RBR doesn't have to process many features while in router mode.
