LloydG
Dec 22, 2021Aspirant
Netgear Orbi RBR50 / Open reach modem UK
Good morning. Can anyone assist. I'm currently using a BT Smart Hub 2 but it doesn't have modem mode. So I've purchased an openreach modem model ( B-Focus V-2fub/r Rev.B). I've connected it to ...
CrimpOn
Dec 22, 2021Guru - Experienced User
LloydG wrote:
Good morning.
Can anyone assist.
I've connected it to DSL , which it recognised and thought it would be a straight forward plug and play to the Orbi Internet / WAN port.
However the orbi is flashing purple and although showing as a network, is showing no IP address.
Could you clarify that the goal is to replace the BT Smart Hub2 with the Openreach modem (B-Focus V-2fub/r)?
I am not having a lot of luck find a user manual for that modem.
