smuv123
Jan 27, 2020Aspirant
Netgear ORBI RBR50 AP vs Bridge
Hello, I currently have my Netgear Orbi RBR50 setup as an AP (Access Point), if I switch to Bridge Mode, do I lose all my settings and configurations? I just wanted to place a firewall with DHCP in ...
- Jan 27, 2020
Thanks for the additional insight and recommendation.
smuv123
Hello, thanks for the quick response. I made a mistake on my original question. Currently I have the RBR50 setup as a router and would like to just switch it as an Access Point (place a rirewall with DHCP in front). If I change to access point, would the current features that are enabled be disabled? While the router will definitely change IP address, would this be also the case for the devices connected via wifi? It would probably be a good idea to backup the settings, before, and after, in case I need to return back to router config. Probably have to do a hard reset to get back to current configuration.
Jan 27, 2020Guru - Experienced User
Most of the router features will be disabled while in AP mode, ie Circle, Armor DHCP server and such. SSID should remain the same.
I recommend setting a static IP for the RBR in AP mode out side the main host routers DHCP server IP address pool. I use 191.168.1.50 for mine. That way you know where to access it all the time.
Yes. always have a back up config saved to file.
