smuv123
Jan 27, 2020Aspirant
Netgear ORBI RBR50 AP vs Bridge
Hello, I currently have my Netgear Orbi RBR50 setup as an AP (Access Point), if I switch to Bridge Mode, do I lose all my settings and configurations? I just wanted to place a firewall with DHCP in ...
- Jan 27, 2020
Thanks for the additional insight and recommendation.
Jan 27, 2020Guru - Experienced User
Most of the router features will be disabled while in AP mode, ie Circle, Armor DHCP server and such. SSID should remain the same.
I recommend setting a static IP for the RBR in AP mode out side the main host routers DHCP server IP address pool. I use 191.168.1.50 for mine. That way you know where to access it all the time.
Yes. always have a back up config saved to file.
