Alisdair73
Mar 13, 2019Aspirant
Netgear orbi RBR50 disconnection
I have the RBR50 with 3 RBK50 satellites. Recently the RBR50 (router) disconnects from the satellites and I have a flashing white ring on the RBR50. It is now doing this regularly and it causes my wi...
Alisdair73
Firmware 2.3.0.32 on router and the 3 satellites
Orbi in ap mode
Router is draytek 2650
Home is 3000sq ft on one level with fairly thick walls in places hence 3 satellites
1st satellite is now only 2m from router! As it sometimes dropped at 8m
Mimo and beamforming enabled
Channels auto will change
1 Wifi neighbour for security purposes runs our security
Orbi in ap mode
CrimpOn
Mar 13, 2019Guru - Experienced User
You did not mention doing a "factory reset" after updating to the latest firmware?
- Alisdair73Mar 13, 2019AspirantI didn’t do a factory reset after firmware update
- CrimpOnMar 13, 2019Guru - Experienced User
Alisdair73 wrote:
I didn’t do a factory reset after firmware updateSeems like the obvious thing to try next. It is a PAIN if there have been extensive customizations, but what other option do you have?
