DTMaurice
Jan 04, 2022Aspirant
Netgear ORBI RBR50 Guest network
I'm trying to move all my smart plugs to the GUEST network to isolate traffic. All the smart plugs will only operate on a 2.4GHz wi-fi connection, and the main network had both 2.4 and 5 GHz. I don...
- Oct 02, 2023
Posting this information here in the event others come searching for a solution to the same problem.
The issue I had was that I reset the pw on my wifi router and needed to re-sync all the Gosund smart plugs to it since they could not longer connect to my wifi with the old pw with which they were originally sync'd.
The Gosund smart plugs can be sync'd/paired via a wifi signal that is broadcast from the plug itself. Instead of putting the plug in a "quick blink" mode (where it is searching for your wifi), you long-press the button again to put it in a "slow blink" mode. Once in slow-blink mode, you will see a new network listed in your wifi connection list called "SmartLifexxxx" which you can select, connect to, and pair the device using an alternate setup procedure.
Here are the steps:
- Open the Gosund app
- Go into each device, click the edit/setup pencil icon in the top-right of the screen
- At the bottom, select "Remove Device", and then select the option to "wipe data". Repeat this process for all plugs that need to be reset
- Back at the main screen, press the "+" button to add a new device
- Select the socket/plug option
- Enter your wifi name and pw
- On the "Reset your device" screen, press "EZ Mode" in the top right, which will display a quick-pick menu
- Select "AP Mode" from the menu
- Plug the device in and confirm it is in 'slow blink' mode and, if not, long-press the button until you get a slow blink
- Select "Go to Connect" to bring you to your phone's wifi setting to select the "SmartLifexxxx" wifi connection
- Return to the app to complete the device connection
This process worked successfully on all eight of my Gosund plugs. I've attached the screenshots sent to me by Gosund when troubleshooting the issue with them.
Hope this helps the next person that runs into this!
mercorelli
Oct 02, 2023Guide
Here are the steps:
