wimmme
Sep 23, 2020Tutor
Netgear Orbi RBR50 IPV6 not working
Hello, I have about the same issue as in this topic, but it's closed and has no answer for me: link My Intern Provider is Telenet (Belgium). I ecently switched modems because i had to. I ha...
- Oct 21, 2023
Just for closing this up: since 15/02/21 this is working as desired ...
https://www.netweters.be/t5/Instellingen-software-hardware/IPv6-op-de-CV8560E-E-router/td-p/96759/page/32#M21427
wimmme
Oct 21, 2023Tutor
Oct 21, 2023Guru - Experienced User
Wow, 3 years later.
- wimmmeOct 22, 2023Tutor
I don't like unfinished posts or people that never come back to report how they got it working, found a post from myself, had to finish it 😉
- FURRYe38Oct 22, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
