mervinsx
Mar 11, 2022Aspirant
Netgear Orbi RBR50 not visible to Fujitsu ScanSnap ix1600
Hi, I have a very strange and peculiar issue. I have a Netgear Orbi RBR50 router with three satellites. The WiFI SSID is visible and 40-50 devices around my house are able to connect to this...
- Nov 25, 2022
Maybe I have a solution, or at least it worked for me
I had the same problem as all of you, my is ORBI RBR50 with a satellite Firmware V2.7.4.24 and Scasnap iX1600 with the latest firmware version available I don't know the version.
Here is the my solution.
In Advanced Setup -> Wireless Setting -> Advanced Wireless Settings (2.4GHz b/g/n)
I unchecked (disabled) , "Enable WMM (Wi-Fi multimedia) settings"
"Enable 20/40 MHz Coexistence" was already unchecked (disabled) from the start.
I haven't touched the other settings:
CTS/RTS Threshold 2347
Preamble Mode "Short Preamble"
Transmit Power Control "100%"It worked for me, in the sense that as soon as I unchecked (disabled) "Enable WMM (Wi-Fi multimedia) settings" the scansnap finally connected to the router.
mervinsx
Mar 13, 2022Aspirant
Thanks Mikey.
The CTS/RTS threshold is already set to 2347 for both 2.4hz and 5Ghz networks.
I am not able to find the 'Enable AX' section under Advanced tab > Wireless Setup! Instead I have the following:
Enable SSID Broadcast
Any idea why I am not seeing the option you mentioned?
Mervin
Mikey94025
Mar 13, 2022Hero
mervinsx wrote:I am not able to find the 'Enable AX' section under Advanced tab > Wireless Setup!
Sorry, my bad. The AX option is not a feature your RBR50 has, only RBR750 and RBR850, so please disregard. So setting CTS/RTS is all my suggestion was to try and you've done that.
