mervinsx
Mar 11, 2022Aspirant
Netgear Orbi RBR50 not visible to Fujitsu ScanSnap ix1600
Hi, I have a very strange and peculiar issue. I have a Netgear Orbi RBR50 router with three satellites. The WiFI SSID is visible and 40-50 devices around my house are able to connect to this...
- Nov 25, 2022
Maybe I have a solution, or at least it worked for me
I had the same problem as all of you, my is ORBI RBR50 with a satellite Firmware V2.7.4.24 and Scasnap iX1600 with the latest firmware version available I don't know the version.
Here is the my solution.
In Advanced Setup -> Wireless Setting -> Advanced Wireless Settings (2.4GHz b/g/n)
I unchecked (disabled) , "Enable WMM (Wi-Fi multimedia) settings"
"Enable 20/40 MHz Coexistence" was already unchecked (disabled) from the start.
I haven't touched the other settings:
CTS/RTS Threshold 2347
Preamble Mode "Short Preamble"
Transmit Power Control "100%"It worked for me, in the sense that as soon as I unchecked (disabled) "Enable WMM (Wi-Fi multimedia) settings" the scansnap finally connected to the router.
RiccardoS
Nov 25, 2022Initiate
