Rolls87
Jul 01, 2020Aspirant
Netgear Orbi RBR50 Port Forwarding for Xbox
Hi All, Looking for some guidance as I have followed instructions to port forward but seems to not be working right as when I search for the port on https://www.yougetsignal.com/tools/open-ports/...
Rolls87
Modem is TP Link N300 W9977
Modem is set to run as Modem only although UPnP shows "on" but no data there.
On the NG Settings:
LAN Section - I've put address reservation for 10.0.0.88 (my PC)
UPnP Section - UPnP is already ON.
Advert period (in mins) = 30
Adver time to live (in hops) = 4
Attached is a screenshot. My PC with IP 10.0.0.88 shows there too.
Jul 01, 2020Guru - Experienced User
So even with the modem in modem only mode, the Orbi is using a 10.something IP address? I guess this will work too. Normally Orib would use 192.168.1.1
Need to be sure the modem is fully bridged.
