kaizenn
Mar 11, 2021Aspirant
Netgear Orbi RBR50 Router+Satellite - Need To Disable Satellite WiFi
NETGEAR Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50) (main router + 1 satellite) Firmware on both: V2.7.2.104 My main router is plugged in to cable modem, and the satelli...
Mar 11, 2021Guru - Experienced User
There isn't a offical way to turn OFF the wifi radios on the RBR or RBS. There designed to be ON all the time. So if the telnet method is one solutoin for you, then you'll need to apply that each time. Be sure you commit the change as well. However this may not support the persist thru a reboot or power cycle.
You might check out Voxels FW as well to see if his FW works better in this area:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883615#
You can revert back to stock FW if it doesn't work out for you.
vajim
Mar 11, 2021Master
what does that mean?
- CrimpOnMar 11, 2021Guru - Experienced User
I installed Voxel's firmware, found that it worked fine, but that I had no pressing need for the added functions and performance gain. Voxel is also based in Europe and when Netgear began that insane "US vs World" versions of firmware, Voxel announced he was sticking with "World". (Now that there is no longer a difference, he may have revisited that position.)
"Revert" means that I did a manual firmware update with stock Netgear firmware and my Orbi is now running the Netgear version.
