kaizenn
Mar 11, 2021Aspirant
Netgear Orbi RBR50 Router+Satellite - Need To Disable Satellite WiFi
NETGEAR Orbi Tri-band Whole Home Mesh WiFi System with 3Gbps Speed (RBK50) (main router + 1 satellite) Firmware on both: V2.7.2.104 My main router is plugged in to cable modem, and the satelli...
vajim
Mar 11, 2021Master
FURRYe38 wrote:
You can revert back to stock FW if it doesn't work out for you.
what does that mean?
CrimpOn
Mar 11, 2021Guru - Experienced User
I installed Voxel's firmware, found that it worked fine, but that I had no pressing need for the added functions and performance gain. Voxel is also based in Europe and when Netgear began that insane "US vs World" versions of firmware, Voxel announced he was sticking with "World". (Now that there is no longer a difference, he may have revisited that position.)
"Revert" means that I did a manual firmware update with stock Netgear firmware and my Orbi is now running the Netgear version.
