albertopm
Mar 09, 2021Guide
Netgear Orbi RBR50 Satellite via ethernet backhaul - satellite loses connection
Hello, I've been using the following setup for over a year with RBR50: 1. Internet modem in bridge mode connected via ethernet to 2. Orbi Router connected via ethernet backhaul to 3. Orbi Sa...
Mar 09, 2021Guru - Experienced User
How is the RBS connected to the RBR? Directly to the back of the RBR or is there a LAN switch in between?
FYI: For users ethernet connecting there RBS to the RBR while on v102 or v104, they may experience an short ARP storm for about a minute or two then it will stop and never appear again:
albertopm wrote:Hello,
3. Orbi Satellite in my office room
In the satellite, in addition to the ethernet backhaul connection I have other devices connected via ethernet, including a Mac computer via a USB-ethernet adapter.
It's been working quite stable with no issues for several months, but recently I ugpraded both devices to the latest firmware (v.2.7.2.104). Since then I am seeing following the following issue:
- Satellite is connected to router via ethernet backhaul indicated by connection Wired in the Orbi app
- Computer 1 is connected to satellite via USB ethernet adapter, wifi is off
- Computer 2 is connected to satellite via wifi
- When I disconnect computer 2 form the USB ethernet adapter, it causes the satellite to lose the backhaul connection and thus any device connected to the satellite will have no internet connection.
It seems hat powering off the satellite, powering it on again and waiting for 10 minutes or so brings it back to normal state. Note this only happens when the computer is unplugged from the ethernet connection.
The ethernet cable connected to both devices is on the first port (next to yellow port on the router, closes to sync button on the satellite).
Is this a known issue? Perhaps a bug in this firmware version?
vajim
Mar 09, 2021Master
ARP storm??
