selva
Jan 13, 2021Aspirant
NetGear Orbi RBR50 with firmware V2.7.0.70 - drops off Internet (almost twice a day)
I see the following text keeps repeating in the file: /var/log/log_message: 5106:[<c021ea2c>] (unwind_backtrace) from [<c021bb24>] (show_stack+0x10/0x14) 5106:[<c021bb24>] (show_stack) from [<c0...
Jan 13, 2021Guru - Experienced User
Are you in the USA region? If not, then you need to use:
If your in the USA then you can try v102:
A factory reset is needed if you encounter problems after loading FW.
- selvaJan 13, 2021Aspirant
I am connected to LinkSys EA9400 and I am unable to upgrade or reset my config to factory reset.
