selva
Jan 13, 2021Aspirant
NetGear Orbi RBR50 with firmware V2.7.0.70 - drops off Internet (almost twice a day)
I see the following text keeps repeating in the file: /var/log/log_message: 5106:[<c021ea2c>] (unwind_backtrace) from [<c021bb24>] (show_stack+0x10/0x14) 5106:[<c021bb24>] (show_stack) from [<c0...
selva
I am connected to LinkSys EA9400 and I am unable to upgrade or reset my config to factory reset.
Jan 14, 2021Guru - Experienced User
Is the Orbi connected behind the Linksysy router?
Is the Orbi in AP mode?
- selvaJan 14, 2021Aspirant
Yes, Orbi is behind the LinkSys router.
Yes, The Orbi is in AP mode.
- FURRYe38Jan 14, 2021Guru - Experienced User
IS the wifi radios on the Linksys router disabled?
You might update FW to v102:
selva wrote:Yes, Orbi is behind the LinkSys router.
- selvaJan 17, 2021Aspirant
Yes, the LinkSys Wifi is disabled and works as just wired router.
As I am unable to upgrade the FW in the current device and the device keeps dropping the internet connection, I had to return this router back to store (as I have no help from Netgear in fixing this bug).
With the different mesh router, the setup is working fine now. Thanks for all of your help.
- vajimJan 15, 2021Master
Perhaps switch this setup around or get rid of the linksys
- selvaJan 15, 2021Aspirant
Tried and fails the same way.
This has been working for the past 8 months. Unfortunately, I see that there is no easy way to get a support person from Netgear to locate the issue and fix it (I see that there is constant dump of thread stack dump in log files in the router). I may have to finally return back to the store and look for a good alternative MU-MIMO router ....
