owlowlowlowl
Apr 11, 2020Initiate
Netgear Orbi RBS10 - Blinking Red - Cannot Perform Factory Reset
Hi Netgear Community, Main Problem: I cannot hard reset the RBS10 satellites. Three of them are currently blinking red. I have tried the 7+ second hold of the reset button, and I have tried the...
Apr 22, 2020Guru - Experienced User
15 second press of the reset button is needed.
If you can't get the system working, I recommend returning the system and try a different system. You may have a faulty system out of the box.
owlowlowlowl
Apr 24, 2020Initiate
Thanks - these were satellites from two different full sets of of the 4-pack from Netgear. I ended up returning these items to Best Buy.
