Dryath's avatar
Dryath
Netgear Orbi RBS850 Wired and Wireless Problems
Moved house so decided to buy the Netgear Orbi RBS850 with 3x satellites to cover the house. So far been the worst experience of a router. One of the satellites tends to drop connection fairly frequently (actually the closest one to the router) my PC is wired directly into the router and frequently drops from 500mbps down to 40mbps that wont change until i perform a full reset on the router.
At the moment feeling like ive wasted alot of money on a system that is way less stable than just using the router provided by virgin...
Anyone got any suggestions?
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
