giabar1974's avatar
giabar1974
netgear orbi satellite offline in AP mode
Hi,
I purchased a netgear Orbi system RBK20.
I configured as AP, and it was ok.
I switched-off the satellite for two weeks, and when I come back, I switched it on again, but it does not connect to router (purple light always on).
I tried to configure the system as router and it works properly again.
But when I try to configure as AP satellite's light is always purple and it compares in offline state.
Please could you help me? I'm getting crazy to find a solution. Before my vacation the system worked perfectly!
Thanks,
Giovanni.
1 Reply
  • giabar1974 wrote:
    Hi,
    Thanks,
    Giovanni.
    I would factory reset the satellite and re-pair.
