j1n's avatar
j1n
Apprentice
Dec 15, 2019
Netgear Orbi satellite RBS50 not syncing to Orbi router (RBR50)
Netgear Orbi satellite RBS50 not syncing to Orbi router (RBR50) after overnight automatic firmware update many months ago. So, why didn’t I try to solve the issue when it happened you might ask? Well,...
  • j1n's avatar
    j1n
    Feb 05, 2020
    After trying to add a support ticket & then call Netgear 2 separate times with no luck receiving support, I became more frustrated about how Netgear doesn’t seem to have a way to contact them once your 90-day support after purchasing a product is up unless you fork over money. Considering this was a random event where Netgear pushed a software update overnight, which seemingly bricked my RBS50 satellite, I’d think the company would be willing to help out in that case, but that’s not what I discovered.
    Anyway, I was determined more than ever to get the RBS50 satellite working again with my RBK53 system. After trying various hard resets and configurations, I hooked my non-functioning RBS50 to my working RBS50 with an Ethernet cable. Then, before I turned on the non-working RBS50, I held in the sync & reset buttons, and at the same time, turned the RBS50 on. The back light initially turned red, started blinking, and then turned off. I let go of all the buttons, and somehow the satellite rebooted and connected to my system. I really do t know how or why this fixed my satellite from connecting to my system, but it did! Problem solved.
