Aronius
Mar 22, 2019Tutor
Netgear Orbi slow WiFi
Hi I just installed my Orbi, by switching my Virgin Hub 3.0 to modem mode , turning it off and turning it back on and then connecting it to my orbi via Ethernet and then turning the Orbi on . I...
Mar 22, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Does the xbox get a IP address if directly connecte to the base router or wirelessly connected?
Disable Instant ON on the xbox.
What devices are you using to speedtest wirelessy?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Aronius wrote:
Hi
I am getting good Wired speeds (350mps+) but 100- on WiFi , I expected more?? Also on my xbox it is saying ‘cannot get an IP address’ ? My Xbox is wired to a switch which is wired to the Orbi?
Please help!!!
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Chuck_M
Mar 22, 2019Mentor
I would double check to truly ensure your modem/router combo is in the passthrough (bridged) mode.
Make sure you also turn off any wireless radios in your original modem/router.
