Dfurn21's avatar
Dfurn21
Netgear Orbi to virgin superhub 3
Hi guys,
hoping someone can help.
i have the Orbis in place since Christmas and whilst they work, they are awesome.
However I having been having problems with losing internet connectivity.
my setup the the virgin media home hub 3 setup in modem mode,
I have the netgear orbi rbr20 running v2.5.1.6 3 pack, one is hardwired linked whilst the third is a via wireless.
Every day or two my internet I will drop out, I can still reach the orbi and ping it via 192.168.0.1,
but am I unable to ping or reach modem on its 192.168.100.1 address (even if i manually set an IP address on that range via hardwired network.
Virgin the ISP have been out twice now, on the 1st visit they said the signal was too strong and out of range so added some kind or resistance to bring signal into spec.
On second visits they proved my connection to cab and onto exchange are ok and swapped the modem.
Im not sure what else I can try at this point?
kind regards
david
1 Reply
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update? Power OFF the modem for 30 seconds then back ON. Walk thru the setup wizard with a wired PC and web browser.
