sdspa
Sep 28, 2018Aspirant
netgear orbi triband rbk 50
I am likely going to buy the Netgear Orbi triband for FIOS. I live in a medium sized house, 3 floors. The router is on the middle floor all the way to the right (towards back yard). If I connect t...
ekhalil
Sep 28, 2018Master
Have you seen this description:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
I hope it helps!
- sdspaSep 28, 2018AspirantThe picture shows router bottom floor and satellite on main floor. Since my router is on the main floor should I put satellite in the basement?
- ekhalilSep 28, 2018Master
If all floors have the same size and building material, then I would guess it's the same if you put the satellite in the basement or the upper floor.
The main thing is to have the satellite around 30 ft from the router if you will use wireless backhaul.
