sdspa
Sep 28, 2018Aspirant
netgear orbi triband rbk 50
I am likely going to buy the Netgear Orbi triband for FIOS. I live in a medium sized house, 3 floors. The router is on the middle floor all the way to the right (towards back yard). If I connect t...
Sep 28, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
sdspa wrote:
I am likely going to buy the Netgear Orbi triband for FIOS. I live in a medium sized house, 3 floors. The router is on the middle floor all the way to the right (towards back yard). If I connect the netgear router on the first floor (right side of house) where should I put the satalite? Upstairs left side of house, basement left side of house or same floor left side of the house?
Thanks,
