KarenBell
Aug 15, 2019Follower
netgear orbi ultra-perfromance and At& fiber
We currently have At&t fiber. Just some preliminary facts of what we're dealing with....we have 4800 sq ft. We have quite a few devices between phones, comp, smart tvs & daughters blue tooth diabet...
Aug 20, 2019Guru - Experienced User
IT would be best to add Orbi as the main wifi ssytem and turn OFF all other exhisting WIfi radios.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
