wnaylor
Aug 15, 2020Follower
Netgear Orbi Voice Smart Speaker
Will/Can the Netgear Orbi Voice Smart Speaker work with my Orbi RBK 750 (WIFi 6) router?
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
FYI, Orbi AC satellites are not currently wirelessly compatible with Orbi AX. You can ethernet connect them to the Orbi AX system in that configuration at this time.
Good Luck.
The Netgear product page for the RBS40V "Orbi Smart Speaker" claims there are two models:
one works "only with Orbi" and the other "works with any router".
https://www.netgear.com/orbi/rbs40v.aspx
FURRYe38is correct that people who have already purchased and installed the AX product are more likely to have personal experience to report. There is also a community forum specifically for the Orbi Voice product:
https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
The Product Data Sheet for the "Orbi" version is (typically) unhelpful. On page 3, "What do I need for Orbi to work?", the answer is "Orbi wireless router." No mention of original Orbi, Orbi Pro, or "AX".
