Virtech
May 19, 2019Aspirant
Netgear Orbi VPN Woes
I'm trying to get the VPN working through the RBR50, have configured the VPN through the netgear interface and then downloaded the Windows config file.
I have the OpenVPN client running on Win...
Virtech
May 28, 2019Aspirant
Hi to answer your questions below:
- Do you have the latest firmware version (2.3.1.60)? Yes it installed
- What version is the OpenVPN client used? 2.4.7
- Are you using a Static IP for your router or Dynamic IP? Static
The Orbi VPN is pretty much useless, I was connected at once stage using a previous firmware version but it was so slow it was unusable.
Chris
