gibrahim
Nov 08, 2018Aspirant
Netgear Orbi vs. IOgear Wireless HDMI
Hi there was a previous post on this topic that was never solved. Pasted here:
https://community.netgear.com/t5/Orbi/Netgear-Orbi-vs-IOgear-Wireless-HDMI/m-p/1218200
I am having the exact is...
Blanca_O
Nov 13, 2018NETGEAR Employee Retired
Hi gibrahim
We’d greatly appreciate hearing your feedback letting us know if the information st_shaw provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
Blanca_O
Nov 18, 2018NETGEAR Employee Retired
Hi gibrahim
Per engineering team, the issue has something to do with interoperability. The IO Gear HDMI TX/RX does not follow 802.11 protocol that makes the Orbi interfere with it.
Blanca
Community Team
- gibrahimNov 18, 2018Aspirant
Thank you Bianca that is helpful! Is there any hdmi tx/rx product that would work with the Orbi? When my satellite is on, I virtually cannot operate the TV - too much interference. When the satellite is off, I can probably use the TV 20% of the time. Eventually it find a channel that would work. But even then I get interference.
Is there any hdmi tx/rx you can recommend to bypass this issue? This is the only way I can watch TV as I use hdmi transmittor from my box (in the closet) to my hdmi receiver next to the TV which is about 30 feet away.
Thanks
- gibrahimNov 23, 2018AspirantThank you very much!!
