SRRS
Aug 16, 2019Aspirant
Netgear Orbi whole home WiFi system
I just bought the orbi whole home WiFi system - 1 x router, 1 x satellite but I can’t set it up because the Ethernet cable does not fit into my BT telephone/broadband socket. Am I doing something wro...
Aug 16, 2019Guru - Experienced User
RJ45 LAN ports are all the same. Try a different LAN cable. CAT6 is recommended.
Which model Orbi system do you have? RBK##?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Something to keep in mind.
SRRS
my current router is a TP Link and plugs into a BT phone adapter which has a phone port and a small box like port and this plugs into the phone socket. I dont think I have a modem?
