SRRS
Aug 16, 2019Aspirant
Netgear Orbi whole home WiFi system
I just bought the orbi whole home WiFi system - 1 x router, 1 x satellite but I can’t set it up because the Ethernet cable does not fit into my BT telephone/broadband socket. Am I doing something wro...
SRRS
Yes I think I currently have the smaller RJ11? plugged from the TP Link router directly into the BT little box which plugs into the phone socket.
SRRS
I dont think I have a modem?
- FURRYe38Aug 16, 2019Guru - Experienced User
Do you have DSL ISP services? There should be a modem or all jack for ISP services.
Phone jacks looks like RJ45 jacks but smaller. The ORbi system uses the larger RJ45 LAN jacks for ISP services and LAN connected devices.
Ensure your ISP service/modem has a RJ45 port for use with the RBRs RJ45 jack. Contact your ISP for help and information on how to connect a router to there ISP service hardware/modem.
