dtskip
Jan 12, 2022Guide
Netgear Orbi won't factory reset...
I was doing some experiments with the vlan settings on my Orbi Router. It reached a point where the web interface wouldn't load anymore, leaving me no choice but to factory reset. The problem is:...
dtskip
Jan 12, 2022Guide
What commands? All I did was double click nmrpflash.exe. I didn't input any commands because I can't, I don't know how to use this.
dtskip
Jan 12, 2022Guide
I also highly doubt it will work anyway, because I don't think it's a firmware issue. My router was working perfectly fine until I disabled DHCP and tinkered with the vlan options. The Orbi router just broke beyond repair.
- plemansJan 12, 2022Guru - Experienced User
I've had nmrpflash recover devices that tftp couldn't. its worth trying
