RussJ
Mar 08, 2019Aspirant
Netgear Orbi/Harmony/Alexa issues - NAT Session Timeout?
I have an RKB40, Harmony hub and Alexa Dot and am having some compatibility issues.
I set up a simple Harmony Activity to switch one item, linked it to Alexa and this works perfectly both via remot...
Mar 08, 2019Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
I set up a simple Harmony Activity to switch one item, linked it to Alexa and this works perfectly both via remote and voice control, so I assume that all the systems are functioning correctly.
However when I try a more complex and lengthy Activity which turns on a selection of items (projector, receiver, screen etc), then only the receiver switches on and nothing else.
I've Googled the issue and it seems that the NAT Session Timeout setting is likely to be the problem.
Can anyone advise how I can amend this value in my Orbi system please?
Russ
- RussJMar 08, 2019Aspirant
Firmware = V2.2.1.210
Operating in Router mode
Modem is a BT Openreach badged Huawei Echolife HG612.
Russ
- FURRYe38Mar 08, 2019Guru - Experienced User
Are all devices connected to the Orbi have reserved IP addresses ON the Orbi router?
NAT has to due with traversal of internet traffic from the modem thru the router to devices.
http://computer.howstuffworks.com/nat.htm
I don't believe this is a NAT issue if your dealing with devcies only on the LAN side of the router.
Are the devices connecte to the base or mixed between the base and satellite?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- RussJMar 08, 2019Aspirant
Thanks for your reply.
I am by no means an expert on all this but since the system works fine with a simple activity but fails with a longer one it suggests to me that a timeout is the issue.
This link explains more:
Changing the timeout value certainly fixes the issue with Draytek routers....
Russ
