RussJ
Mar 08, 2019Aspirant
Netgear Orbi/Harmony/Alexa issues - NAT Session Timeout?
I have an RKB40, Harmony hub and Alexa Dot and am having some compatibility issues.
I set up a simple Harmony Activity to switch one item, linked it to Alexa and this works perfectly both via remot...
RussJ
Mar 17, 2019Aspirant
Sorry about the delay in getting back to you on this. I didn't get any notification that someone had replied.
I ran tracert 8.8.8.8 with the following result:
Microsoft Windows [Version 10.0.17134.648]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\Users\russe>tracert 8.8.8.8
Tracing route to google-public-dns-a.google.com [8.8.8.8]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 * * * Request timed out.
3 8 ms 8 ms 8 ms 31.55.186.177
4 9 ms 8 ms 9 ms 31.55.186.184
5 8 ms 8 ms 8 ms host213-121-192-120.ukcore.bt.net [213.121.192.120]
6 9 ms 13 ms 9 ms peer3-et-0-0-0.redbus.ukcore.bt.net [62.172.103.236]
7 9 ms 9 ms 9 ms 109.159.253.3
8 * * * Request timed out.
9 11 ms 11 ms 12 ms 72.14.237.58
10 9 ms 9 ms 9 ms 216.239.54.83
11 9 ms 9 ms 9 ms google-public-dns-a.google.com [8.8.8.8]
Trace complete.
Not sure what this means, can you help?
Russ
Mar 17, 2019Guru - Experienced User
Means you don't have a router built in with the ISP modem which your model suggested its only a modem.
Trace complete.
Russ
