RussJ
Mar 08, 2019Aspirant
Netgear Orbi/Harmony/Alexa issues - NAT Session Timeout?
I have an RKB40, Harmony hub and Alexa Dot and am having some compatibility issues.
I set up a simple Harmony Activity to switch one item, linked it to Alexa and this works perfectly both via remot...
RussJ
Mar 18, 2019Aspirant
Nat Filtering is set as "secured"
There is also a check box called "disable SIP ALG" and this is unchecked.
Mar 18, 2019Guru - Experienced User
Try disabling NAT Filter only, save settings and reboot the RBR and Alexa devices. See if this does anything. If not, seems like there maybe an issue that NG support needs to look into.
- RussJMar 18, 2019Aspirant
Could you just clarify:
I have two options for NAT filtering - "secured" or "open" - which should I choose?
And should I check the disable SIP ALG or leave as is?
- FURRYe38Mar 18, 2019Guru - Experienced User
Try open, if nothing changes, set back to secure.
Try can try checking Disable SIP ALG, if nothing changes, change it back.
Will do but it might have to wait until tomorrow morning as the Boss is ensconced in the lounge watching EastEnders and I don't think she'd appreciate me fiddling around with the AV system at the moment.
Thanks for your help and I'll report back in due course.
Russ
