TRBN
Jul 25, 2019Tutor
Netgear OrbiRBK22
Hi
Quite surprised that the latest Netgear ORBI RBK22 purchased from Costco is not having multi-voltage adaptors coming with the units. How come ? In this case, we cant use these units in coutnry where the input Voltage is 220-230V 50 Cycles ??
Can any body suggest as to how to use it with input voltage 220-230V
If you bought from Costco in the USA then most units were designed and Mfrd for USA voltages only. Not meant for any other countrys outside of the USA. If your tring to export then to a different country with different voltages other than v110 then you'll need a voltage transformer/converter.
