Troyd75826
Feb 08, 2018Guide
Netgear, please please please allow end user to turn off automatic firmware updates!!!
Firimware updates 2.1.1.16 and 2.1.1.18 are totally unstable with random, constant loss of wifi. I must constantly reboot the router. Prior firmware 2.0.0.56 is very stable for me and I would like t...
Troyd75826
Feb 09, 2018Guide
Yes, I have done that, and it seems to work. But we should not have to hack config files just to keep something that we know works as it is. Please read Netgear!
webminster
Feb 09, 2018Luminary
I personally (and others as well) have found the telnet hack to be unreliable. The firewall block is the only really reliable way to block auto-updates.
- Retired_MemberFeb 09, 2018
Although allowing the user the ability to turn off auto-updates may be a positive thing, I'm curious about the following:
Number of Orbi systems sold______
Number of Orbi systems with little to no problems_______
Number of Orbi systems with too many problems_______
- t_kFeb 09, 2018Luminary
VAJim,
I can help you with that!
Number of Orbi systems sold: Millions
Number of Orbi systems with little to no problems: 0
Number of Orbi systems with too many problems: Millions
What you're looking for is "How many users have *noticed* the Orbi system problems".
Since the disconnect issues are not immediate, the backhaul issues are based on traffic, and firmware upgrades only cause issues if you *happen to notice*, the number of people who notice is probably low.
The issues are completely reproducable given a proper test case, across all Orbi's. If you only use wifi on and off for a few hours each day you may never notice that it drops all the time. Not noticing a problem is completely different from not having one.
- Mayhugh1Feb 09, 2018Apprentice
To be fair, I'd say it is more like 10% after looking at the Amazon reviews.
- Troyd75826Feb 09, 2018GuidePlease describe firewall block in detail.
