Shahab
Apr 17, 2020Apprentice
Netgear Pro support plans
I have a Netgear Orbi Mesh WifFi system (RBR0 Router + 2 RBW30 Satellites) with which I have been having connectivity issues for the past month and been unable to get any traction from Netgear suppor...
CrimpOn
Apr 17, 2020Guru - Experienced User
Shahab wrote:I have a Netgear Orbi Mesh WifFi system (RBR0 Router + 2 RBW30 Satellites) with which I have been having connectivity issues for the past month and been unable to get any traction from Netgear support. I was thinking about a premium support plan, Netgear offers a couple of different plans for home users. The more affordable plan is the ProSupport plan (https://prosupport.netgear.com/home/), however that doesn't support the RBR40 (https://kb.netgear.com/000055591/Which-products-are-covered-by-NETGEAR-ProSupport-for-Home) even though it does support other Orbi systems such as the RBS40. Anyone know why this is? Netgear also offers the GearHead support plan (https://gearhead.netgear.com/) but that's pretty expensive. I don't want support for all devices in my house, just the Netgear WiFi system. Shahab
Caveat: I have not purchased a support plan from Netgear. (I am too cheap.) I believe your aprehension is unfounded. The list of supported products clearly includes the RBK33, which includes exactly the products you mention, i.e. one RBR40 and two RBW30 wall units: https://www.netgear.com/images/datasheet/orbi/RBK33.pdf My guess is that whoever compiled the list simply "missed" the RBR40.
As for the merits of the different support plans, "I got nothin."
- ShahabApr 17, 2020Apprentice
I tried to purchase the plan by putting in the serial # of both the router and the satellite but got a message that the products weren't supported when I clicked on purchase. Unfortunately this was a measure of last resort, my experience with their "regular" support has been horrible, my case has been open for almost a month now and I haven't found a way to talk to the 2nd level support directly. I don't know what's causing the constant connection drops, I can't find anything in the standard logs and have also run packet captures from the Debug page and gone through the logs generated that way and haven't found anything.
My thread:
https://community.netgear.com/t5/Orbi/Change-DNS-Settings-on-Orbi/m-p/1886959#M87231
Thread with similar issues:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Circle-frequent-DNS-failures/m-p/1892791#M88491
- Retired_MemberApr 17, 2020
did your system ever work properly?
if it did, what changed?
I've had the system for a year now and the system worked beautifully until just about a month ago when everyone started the quarantine. Initially the issues were DNS related, probably caused by Circle. That changed once I got the replacement units, since then the issue is just the connection dropping altogether multiple times a day.
