rvds61
May 26, 2019Follower
netgear RBK23
one of my satellite orbi's turns now and then purple, than red, after that it turns blue agian. This is very disturbing because it is situated in my bedroom. What could be the problem??
May 26, 2019Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
rvds61 wrote:one of my satellite orbi's turns now and then purple, than red, after that
