redflame910
Aug 17, 2021Aspirant
Netgear RBK50-100NAR Orbi Home Mesh Wi-Fi System
Hello I purchased the Netgear RBK50-100NAR Orbi Home Mesh Wi-Fi System in 2020. It worked great for a year. Suddenly in the past two weeks it goes down every 5 to 15 minutes. The signal from my modem...
redflame910
It is a Motorola and Model is E31U2V1
What exactly happens when this occurs?
The network disappears from our network list in wifi settings. The modem still shows it is on with no disruption.
Does the top ring LED turn ON on the RBR or RBS?
I have noticed some of the light spins blue on top of the Orbi.
For the most part the network disappears momentarily and then reappears. Thanks for responding.
Aug 17, 2021Guru - Experienced User
If the top ring turned ON it means something happended between the RBR and the modem where it caused the RBR to lose it's connection to the modem and short enough that the PINK light didn't come ON but the BLUE one did indicating the RBR got a connection again. Possible intermittent loss of signal on the ISP like or modem and modem would not exatctly tell you this.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. Have them check for any signal loss or log entries ON the modem. This modem model is not the greatest and have seen others have similar problems with this model modem with Orbi systems. Might ask for something different or ask about using your own modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
What is the distance between the router and 📡 satellite(s)?
