rudgo
Apr 03, 2019Aspirant
NEtgear RBR 50
brought this Router and two satelites they work well however, one of the satelites drops the 2.4ghz connection to my wifi cameras every two days in order to fix this i have to reboot the satelite and...
Apr 03, 2019Guru - Experienced User
Minimum recommended distance between router and satellite is 30 ft.
have you tried setting a static connection or reserving the IP address for the camera's?
Does the problem only resolve if you reboot the satellite? not if you reboot the camera?
rudgo
Apr 04, 2019Aspirant
All cameras are set to static when i reboot the cameras it does not resolve the issue it only resolves when i reboot that particular satellite the camera connected to the 2nd satellinte does not drop. What i notice when the cameras drop they connect to the router bacause they cant see that satellite anymore but the router is to bit too far for the cameras
- plemansApr 04, 2019Guru - Experienced User
have you tried resetting that satellite?
What firmware is the RBR50 and the satellites on?
Could you swap around the 2 satellites to see if that helps?
Have you checked to see within the camera forums if anyone is having similar problems with those specific cameras? I run several security cameras of Orbi and haven't had drops or problems.
