rudgo
Apr 03, 2019Aspirant
NEtgear RBR 50
brought this Router and two satelites they work well however, one of the satelites drops the 2.4ghz connection to my wifi cameras every two days in order to fix this i have to reboot the satelite and...
ekhalil
Apr 11, 2019Master
rudgo wrote:
brought this Router and two satelites they work well however, one of the satelites drops the 2.4ghz connection to my wifi cameras every two days in order to fix this i have to reboot the satelite and everything works again any advise will be appreciated. the router is located about 15 ft from the satelite and the cameras is about 20ft away from the satelite.
thanks
It can be that you have interference / disturbances on one of the 2.4 GHz channels. Please make a wifi radio scan around the camera and try to select the least used channel and set it as your 2.4 GHz channel in Orbi.
rudgo
Apr 11, 2019Aspirant
Will try that scan thanks whats the best phone app you reccommend to do this scan
thanks
- ekhalilApr 11, 2019Master
If you have a Macbook then it has a built in wifi scanner.
Otherwise I also use the Apple Airport Utility app in my iPhone which also have abuilt-in scanner. I guess that the same app is available for Android as well.
- rudgoApr 11, 2019Aspirant
Thanks
