rudgo
Apr 03, 2019Aspirant
NEtgear RBR 50
brought this Router and two satelites they work well however, one of the satelites drops the 2.4ghz connection to my wifi cameras every two days in order to fix this i have to reboot the satelite and...
rudgo
Apr 11, 2019Aspirant
Will try that scan thanks whats the best phone app you reccommend to do this scan
thanks
ekhalil
Apr 11, 2019Master
If you have a Macbook then it has a built in wifi scanner.
Otherwise I also use the Apple Airport Utility app in my iPhone which also have abuilt-in scanner. I guess that the same app is available for Android as well.
- rudgoApr 11, 2019Aspirant
Thanks
