kevin009
Nov 07, 2021Star
Netgear RBR850 wireless speeds are dropping
I have an RBR850 with satellite and since I got it about a hear ago, it has been working great. When I set it up and did wireless and wired speed tests, they were screaming fast and blew my socks off...
Nov 09, 2021Guru - Experienced User
Please continue to post in your thread over in the Orbi AX forum:
Thank you.
752User wrote:
I am encountering the same issues with my 752 - wiFi is maxed out at 20 Mbps...
No solution so far..
kevin009
Nov 09, 2021Star
Ok, I've moved this post to here (for those who are also interested and seeing the same issue):
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Netgear-RBR850-wireless-speeds-are-dropping/m-p/2160998#M22799
- FURRYe38Nov 09, 2021Guru - Experienced User
đ
