ole7815
Jul 06, 2021Aspirant
netgear RBS50-V2.7.3.22.zip has rbr50 image
netgear RBS50-V2.7.3.22.zip has rbr50 image is this correct?
- Jul 07, 2021
svetaketu wrote:It should be working now: https://kb.netgear.com/000063811/RBR50-RBS50-Firmware-Version-2-7-3-22
Yes, thank you. It is working this morning (7/7) but was not working earlier last evening regardless of which browser I used.
ole7815
I just downloaded the newest version and it is still bad.
Look at the rbr50-v2.7.3.22.img file, wrong name and wrong size. Rbs50 file is around 25k.
tagteam
Jul 06, 2021Virtuoso
ole7815 wrote:I just downloaded the newest version and it is still bad.
Same here. Every RBS50 zip file I've downloaded has the RBR50 image file in it.
FWIW, I've tried 3 different browsers.
- FURRYe38Jul 06, 2021Guru - Experienced User
I'm using Opera GX. I just noticed that while on my Mac Laptop, the browser downloaded the wrong sized file. I selected the file again from the same link and it then downloaded the right sized file. Can you try this as well? Try Opera GX using the link from here:
Just select the RBS50 file a couple of times and see if it will download the right size file. The file should be 23MB, Not 44MB.
- svetaketuJul 06, 2021Luminary
- tagteamJul 07, 2021Virtuoso
