Jetdrive
Mar 06, 2020Luminary
Netgear routers are at risk of getting hacked: What to do
Netgear this week has pushed out a passel of patches for its home networking gear, covering seven modem-router gateways, one range extender and 40-odd routers, including some Nighthawk models and Orb...
liverman
Mar 07, 2020Tutor
Be sure to click on the link for each vulnerability in the Tom's article and read the specifics.
For example, for my R7000, only one of the four effects my R7000:
Security Advisory for Post-Authentication Command Injection on Some Routers and Gateways, PSV-2018-0352
https://kb.netgear.com/000061760/Security-Advisory-for-Post-Authentication-Command-Injection-on-Some-Routers-and-Gateways-PSV-2018-0352
which says:
R7000, running firmware versions prior to 1.0.9.42
I am running the latest firmware which is V1.0.9.88_10.2.88. So these alerts do not apply to me and my R7000. Ho hum, big nothing burger for me.
But if you have a model and firmware level that is impacted, it is a big deal...but look at the specifics before asking "where is the new firmware".
My process with these things is:
- Follow each link in the article to find the Netgear KB article describing the vulnerability
- Check for my model number and the firmware level that is vulnerable
- Look at my current firmware version on my router. If I am patched past that firmware, this does not effect me
- CrimpOnMar 07, 2020Guru - Experienced User
I agree entirely with this analysis, and did the same thing. My frustration is with the Netgear "Chicken Little" press release. "Vulnerable! Vulnerable! Must upgrade to the March, 2020 security update."
- theoakMar 07, 2020Luminary
So with regards to the Orbi's it lists:
- RBR20, running firmware versions prior to 2.3.5.26
- RBS20, running firmware versions prior to 2.3.5.26
- RBK20, running firmware versions prior to 2.3.5.26
- RBR40, running firmware versions prior to 2.3.5.30
- RBS40, running firmware versions prior to 2.3.5.30
- RBK40, running firmware versions prior to 2.3.5.30
- RBR50, running firmware versions prior to 2.3.5.30
- RBS50, running firmware versions prior to 2.3.5.30
- RBK50, running firmware versions prior to 2.3.5.30
So it appears then that if you have 2.3.5.30 or higher, like 2.5.1.8 you should be good.
- FURRYe38Mar 07, 2020Guru - Experienced User
